02-05-2022 04:57 AM
When onboarding new edge routers, when is a device considered to be onboarded? Does a device need to be in vManage mode to be officially declared "onboarded"?
The reason I ask is some documentation says that a device template is required for onboarding. Adding a device template essentially puts the device into vManage mode through the eye of vManage. But technically you can onboard a device into CLI mode.
Solved! Go to Solution.
02-05-2022 06:08 AM
02-05-2022 06:08 AM
02-06-2022 05:15 PM
Thanks for the feedback. Everything you mentioned makes sense.
Thanks again!
Jason
