2.2.b i Onboarding new edge routers
Jason Spring
When onboarding new edge routers, when is a device considered to be onboarded? Does a device need to be in vManage mode to be officially declared "onboarded"?
The reason I ask is some documentation says that a device template is required for onboarding. Adding a device template essentially puts the device into vManage mode through the eye of vManage. But technically you can onboard a device into CLI mode.
Lei Tian
Onboarded means have control connections with all controllers. It doesn’t have to be in vManaged mode. I think reason the document says template is required probably referring to onboarding edge from PnP. Edge router will pass vbond authentication and get vManage’s information but it needs minimal system and tunnel interface config to build control connections, for pnp to work this minimal configuration is from template. If you don’t need pnp, this minimal config can be manually configured.
HTH,
Lei Tian
Lei Tian
HTH,
Lei Tian
Jason Spring
Thanks for the feedback. Everything you mentioned makes sense.
Thanks again!
Jason
