Ansible copy broken for release 19.1.0
richwood
I've been playing with the anisble viptela workshop in VIRL (https://github.com/ciscops/viptela-workshop), but this appears to be broken in release 19.1.0
I get the following error on the vEdge devices:
<172.16.1.58> SSH: EXEC sshpass -d10 ssh -vvv -C -o ControlMaster=auto -o ControlPersist=60s -o StrictHostKeyChecking=no -o 'User="admin"' -o ConnectTimeout=10 -o ControlPath=/home/woodr/.ansible/cp/fd4e0240c8 -tt 172.16.1.58 '/bin/sh -c '"'"'/usr/bin/python /tmp/ansible/admin/ansible-tmp-1562759112.88-161906205160738/AnsiballZ_copy.py && sleep 0'"'"''
<172.16.1.58> (134, 'fips_md.c(147): \r\n/bin/sh: line 1: 10436 Aborted (core dumped) /usr/bin/python /tmp/ansible/admin/ansible-tmp-1562759112.88-161906205160738/AnsiballZ_copy.py\r\n', 'OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n 7 Dec 2017\r\ndebug1: Reading configuration data /etc/ssh/ssh_config\r\ndebug1: /etc/ssh/ssh_config line 19: Applying options for *\r\ndebug1: auto-mux: Trying existing master\r\ndebug2: fd 3 setting O_NONBLOCK\r\ndebug2: mux_client_hello_exchange: master version 4\r\ndebug3: mux_client_forwards: request forwardings: 0 local, 0 remote\r\ndebug3: mux_client_request_session: entering\r\ndebug3: mux_client_request_alive: entering\r\ndebug3: mux_client_request_alive: done pid = 23580\r\ndebug3: mux_client_request_session: session request sent\r\ndebug1: mux_client_request_session: master session id: 2\r\ndebug3: mux_client_read_packet: read header failed: Broken pipe\r\ndebug2: Received exit status from master 134\r\nShared connection to 172.16.1.58 closed.\r\n')
<172.16.1.58> Failed to connect to the host via ssh: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n 7 Dec 2017
The installation works fine on vEdge release 18.4.1, so what changed in release 19.1.0 to break this?
The relavant error message is: OpenSSL internal error, assertion failed: Digest update previous FIPS forbidden algorithm error ignored.
This occurs during the execution of the script AnsiballZ_copy.py on the vEdge device, when the python script is unzipping the file.
Is this a change in behaviour for 19.1.0 to enforce some additional security? e.g FIPS mode. If so, can it be disabled?
Thanks.
ekhabaro
Hi there,
You're right, OpenSSL library was updated and that led to some issues like for example CSCvp67373.
I advise opening TAC case to investigate on this further, probably it will end up with another bug related to that OpenSSL library upgrade.
ekhabaro
Hi there,
