creating a wan edge list for a lab only
tonypearce1
Level 3
Level 3
Cisco does not allow me to use the plug and play portal to create a wan edge list, even for lab purposes.
Is it possible to create the CSV manually? I've downloaded an empty WAN edge list from vManage. Are there any guides to do this?
note: the reasons I am unable to use cisco.com is that I need a smart account.
- I would create a smart account but cisco prevents me from doing so because my cisco.com account is assigned to the company whom I work for and they already have a smart account created.
- I've had to assign my cisco.com account to the company I work for because cisco.com no longer permits private email addresses as user emails, which means it's impossible for me to hold a cisco.com account while either being unemployed OR not owning a private internet domain name which has a mail server and MX records that can receive mail
I dont need to involve my employer for private/personal education reasons and this should not impact my employer.
5 Replies 5
Hey @tonypearce1 i do not know the answer to your question, but if you are looking for free access to a lab to practice/learn etc.. check the devnet sandbox's https://devnetsandbox.cisco.com/ - we have three SD-WAN fabric pre-built or you can use CML and build this from scratch.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thank you for the quick reply, unfortunately the website is broken again with the below. I'll try again tomorrow.
"504 Gateway Time-out
nginx/1.13.12"
@tonypearce1 that's odd, no problem with the URL here - you can try the links from the main SD-WAN page https://developer.cisco.com/sdwan/
Its work on my side. Do you check now.
tonypearce1
Level 3
Level 3
Thanks all
