Cisco SD-WAN : Packet Capturing/Traffic Mirroring
RS19
Level 4
Level 4
I have the attached high level SD-WAN network.
There are 3 locations. Location A,B & C . All are interconnected using SD-WAN.
In location 3, I have connected L3 switch behind the SD-WAN device. To this switch packet capturing server is connected.
My requirement is that I want to capture all the traffic flowing between Location C -> Location A & B and vice versa.
I want to know what is the best way to achieve this.
I can think of 2 solutions.
1. Via SD-WAN mirroring policy
2. Configuring SPAN port in SD-WAN (Not sure , if is supported or not)
Need suggestions and the best and recommended solutions for this.
ericgar
Hi RS19,
This is Eric from SD-WAN Team.
1.- Mirroring Policy can impact the network performance and overwhelm routers forwarding processor by duplicating the traffic. So it's only suggested on certain flows that requires the packet duplication.
2.- IOS-XE SDWAN and vEdge routers don't support SPAN. Even if its configurable via CLI. Only EPC and Packet Trace are supported.
To continuously capture all traffic from point C to A/B, it's suggested to use another alternative such as a Switch behind the routers.
Hope this helps.
Eric.
@ericgar
Thanks for your reply.
Regarding point no 1, I understood.  Even my thought was the same it could lead to performance impact.
Regarding point no 2, is there any official document in which these are captured. If so could you please share the same ?
Regarding EPC let me know if this is same like capturing the packets using SPAN port ? Is it same or different ?
If there is difference what is the difference ?
Any inputs pls
EPC is Embedded Packet Capture (using monitor capture commands), packet trace not direct way of capturing.
https://www.cisco.com/c/en/us/support/docs/routers/xe-sd-wan-routers/215119-example-of-ios-xe-sd-wan-issues-troubles.html
Btw, in vManage GUI for devices > troubleshooting there is possibility of capturing using vmanage GUI (although this feature is not supported for all).
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/221085-perform-a-packet-capture-on-sd-wan-vmana.html
Use, EPC - monitor capture on LAN facing (service side) interface.
HTH,
