Bookmark
Subscribe
549
Upgrade to 20.15 broke web certificate
dijix1990
For my test environment I upgraded sdwan controllers from 20.12.3 to 20.15.1 for testing sd-routing, after upgrading I found that web certificate flew off. I tryied to regenerate CSR and found that it got errrors with SAN DNS (vmanage returns an error that you cannot use SAN like name sdwan-test or 192.168.100.100). Before I added SAN DNS like - "sdwan-test.lab.ru sdwan-test 192.168.100.100" now I can use only sdwan-test.lab.ru. So I regenerate CSR and tried to import new certificate and I got another error
balaji.bandi
is this self-signed ? and signed by same root CA as before.
you have DNS entries for sdwan-test.lab.ru
If the root ca changed you need to get root ca added.
I used in Lab with latest and works for me.
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/215103-how-to-generate-self-signed-web-certific.html
BB
I use Enterprise CA
Root doesn't changed, of course I have dns and I signed it the same root CA and root CA exists on the vmanage. For 20.12.3 it worked and after updating my Web certificate replaced self-signed, and certificates certifying controllers remained the same - enterprise
