Cisco Sdwan Router LTE Card issue
Rahul NIrmalkar
The LTE card is not showing in the Cisco SDWAN Router ISR-4331.
The card shows up after restarting the router 2-3 times. What could be the issue in it?
@Rahul NIrmalkar hi, check if the router firmware version compatibility with card. also check when router reboot, if its detecting card properly or if it throw any issues.
Good luck
KB
Also check the messages displayed on the console during boot and share them here.
Regards, LG
*** Please Rate All Helpful Responses ***
