12-19-2019 08:34 AM
Can anyone provide the latest documentation for creating the Azure vEdge device version 19.x for extending SDWan into Azure.
the only documentation out there is this one - Create vEdge Cloud VM Instance on Azure
But it calls for using the "Cisco vEdge Cloud Router (3 NICs)" which is not available anymore on Azure, the other option is the "Cisco vEdge Cloud Router" but it is a single Nic deployment with no Cisco documentation for deploying, i assume you have add the other Nics manually.
Also any documentation on deploying a redundant pair of vEdges in Azure would be appreciated.
12-26-2019 01:36 PM
I am not sure , if you have already referred the following documentations:
Hitesh Sood
05-11-2020 01:05 AM
You can use "Cisco vEdge Cloud Router Solution (4Nics). And Later you can define interface as Transport, Service and Management. You can use existing vNet or New vNet when you install this vEdge.
If you choose new vNet, you need to connect vNet-to-vNet after installation vEdge to connect separate vNet.
