02-23-2022 04:58 PM
We had setting with dual DHCP helper addresses on device template.
Recently, I made some change on the device template via [Configuration]-[Devices]-[Change Device Values], but the Change wasn't completed because of dual DHCP helper address.
It was successfully processed when I pull out one of helper addresses and left only one at the field.
Why does this happen?
And how can I resolve thos?
02-23-2022 05:08 PM
You should be able to add up to 4 ip helper address. So, the problem was not related to the number of helper. Make sure you did not use incorrect syntax.
02-23-2022 06:54 PM
Hi Flavio,
Just found out that our vmanage version has the bug relating to dual helper address.
It's needes to upgrade to fix it.
Thank you for your comments.
