05-24-2022 05:13 AM - edited 05-24-2022 05:14 AM
Hello everyone
I`m doing a SD-WAN lab on Pnetlab on Vmware Esxi
And my problem is when I want to generate CSR for vManage to sign it in the certification authority in Windows Server,I`m getting fail.According to pictures I use Enterprise root certificate which the certification authority is Windows server and I do not want to use OpenSSL and I will continue with Windows server
Important note is when I use manual option for Control certificate authorization the vmanage CSR has generated successfully but even by using manual in the next steps like importing certificate for vEdge I face with another problem so my only option is continue with Windows server authority.
I`m in need of your valuable information to solve my problem.
You may see my problem in the pictures attached
Solved! Go to Solution.
05-24-2022 06:43 AM
manual means- Cisco manual, you generate CSR , copy paste to PNP portal of Cisco and get certificate.
You need enterprise option to use your local CA and of course you must import route certificate chain to vManage, so it and other controllers can have this root CA and trust certificates signed by root CA.
HTH,
05-24-2022 06:43 AM
HTH,
05-24-2022 10:11 AM
I have already uploaded the root certificate to vManage otherwise it will not let me to generate CSR for vManage but the problem is even by uploading the root certificate to vManage it does not generate CSR to sign in Windows server as Certificate authority
If you see the pictures you will get my point
07-06-2023 01:43 AM
I am also facing the same issue , please suggest the solution and root cause if possible why we genrally faced this kind of issue ... not able to proceed further........
07-06-2023 01:47 AM
Hello @sumitku8 I have solved this problem by updating images to v19 and then they could easily generate CSR
07-06-2023 01:47 AM
Open new topic with details.
