03-06-2021 10:23 AM
My setup is two cEdges running VRRP. In my scenario,cEdge01 is Master and has two ISPs connected to it. cEdge02 is Standby and has one ISP connected to it. Each TLOC-X has it's one cable, so three cables connecting between the cEdges. All vManaged. Ok
So TLOC-X is fully configured, I see three control connections on both cEdges.
For tshooting purposes and to make sure it works, I disconnect ISP 1 and 2 for cEdge01, hosts don't have internet anymore. Why isn't the traffic going over TLOC-X for ISP3?
I called TAC and he's not seeing anything and confirmed all config is good. I'm going to tshoot with him when I can disconnect the ISPs again, but that's not until later next week.
Has anyone ran into this issue?
I also have ZBFW enabled. Could this be a factor? TAC didn't think so.
Solved! Go to Solution.
07-15-2021 02:09 PM
So I ended up working with TAC on this and to get it working, I had to enter a default route pointing to the IP of the TLOC interface on cEdge02. Although this does make sense and I did think about adding it but it was not a command listed or mentioned on the documentation unfortunately.
03-06-2021 11:07 AM
where is this test conducting? from behind FW?
from the router ISP3 connected should be able to have connectivity? has this been verified.
03-06-2021 11:09 AM
The firewall and router is the cEdges. There is no separate devices.
There is no issue with ISP3. It has full connectivity if I make cEdge02 the Master.
07-15-2021 02:09 PM
07-05-2023 09:36 PM
I had the same problem but even with static default routes pointing to the other vEdge doesn't work.
I would like to extend biz-internet connection from vEdge60 to vEdge61 but not sure why is it not working and am i missing something? Thanks in advanced!
vEdge60 interface ge0/0 connects to biz-internet
vEdge61 interface ge0/0 connects to mpls
Both are connected to each other over interface ge0/2
As shown below, i am not seeing biz-internet
07-06-2023 02:03 AM
Please, open new topic with details and continuing to discuss there.
