05-22-2023 03:13 PM
how to check bfd logging in cisco sdwan fabric
05-22-2023 03:32 PM
Where are teying to see this? vManage ? Or router ? Which version ?
05-22-2023 03:55 PM
Both vmanage (GUI) and vedge (CLI)
Version - 20.3.3
05-22-2023 04:59 PM
"BFD for routing protocols in Cisco SD-WAN cannot be monitored through Cisco vManage. Use CLI show commands for monitoring BFD for Cisco SD-WAN routing protocols."
On the router you can run "show bfd session "
05-22-2023 10:46 PM
you can generally see BFD status via CLI: show bfd session (in IOS XE show sdwan bfd session) or in vManage by choosing device from Monitor page, then Real time > BFD sessions.
However, if you would like to see logs (like BFD down or UP), it can be seen in vManage > Monitor > Logs > Alarms. There can be different BFD alarms. See table 1 from below link:
You can do alarm notification to email if needed. From the above doc we see that from 17.6.3 BFD syslog logging is supported (which can be forwarded to external syslog server too). However, this command is not supported in vEdge (I've checked even on 20.11 latest version).
"Starting from Cisco IOS XE Release 17.6.3, the alarms alarm bfd-state-change syslog command is used to view the BFD state change syslog message for any BFD state change event in the device. For complete details, see alarms alarm bfd-state-change syslog command.
Device(config-system)# alarms alarm bfd-state-change syslog
Device(config-alarm-bfd-state-change)# commit
Here is an example for BFD state change syslog message:
Jul 10 07:09:07.583: %Cisco-SDWAN-vm5-FTMD-5-NTCE-1000009: BFD-session 10.1.15.15:12346 -> 10.1.16.16:12366,
local-tloc-index: 32775 -> remote-tloc-index: 32777, TLOC- local sys-ip: 172.16.255.15, local color: lte -> remote
sys-ip: 172.16.255.16, remote color: lte, encap: IPSEC, new state->UP delete:false, reason:
For advanced troubleshooting scenarios you can use debugging BFD (supported on vEdge too) as indicated in this doc:
