Template Push Error - An element value is not correct : is-vmanaged
lsoleraa
Hello Guys,
I'm currently doing a SD-WAN lab and I'm trying to push a device template to my vEdges but I get the following error:
[13-Apr-2023 0:51:04 UTC] Sending configuration to device
[13-Apr-2023 0:51:08 UTC] Device failed to process request. Error Message - application communication failure
Error Path -
/rpc/edit-config/config/viptela-system:system/viptela-system:is-vmanaged
An element value is not correct : is-vmanaged.
Any help on this would be appreciated.
NOTES:
- Templates are correctly configured.
- Connection to the device is OK, all ports and protocols are allowed.
- vManage version: 20.6.3.1 (single node)
- vEdge version: 20.6.3
lsoleraa
Hello Community,
I was able to solve this issue. The root cause is not identified.
But I highly suspect that there was an issue when I generated the Root CA. I think I wrote another organization name by mistake.
I rebuild my SD-WAN lab, started from scratch and now everything is ok. The push template task was successful.
Best regards,
Luis.
6 Replies 6
What does system template contain? What are values you entered manually?
HTH,
Hi Kanan,
Sorry, I reply until now, I have been really busy for the last few weeks.
On the system template everything is pretty much on its defaults, I attached screenshots.
Here are the system template screenshots, but in the Google Drive link you will find all the screenshots of each feature template added to the system template.
https://drive.google.com/drive/folders/1At1gHkHTo_CLckE0jMF6-9mVvXmakJmu?usp=sharing
Sorry, but these folders don't contain system template details. You've attached device template in this topic and in system folder as well.
HTH,
Oh just noticed that, here are the other screenshots, I hope this time they be the right ones. Everything is on its default.
What variable inputs do you enter for systemIP, sideID, hostname?
In addition, you can try to create custom system template and attach to device template. From these pictures, I don't see an issue, in general.
HTH,
lsoleraa
Hello Community,
Best regards,
Luis.
