https://sandboxsdwan.cisco.com:8443/ is DOWN
amcastagna
Sandbox is once again not working :(
6 Replies 6
poetmj30509
When you login it will redirect to https://sandboxsdwan.cisco.com/index.html. I think this is a miscnfiguration so all you have to do is to prefix the port :8443 and it will work like this https://sandboxsdwan.cisco.com:8443/index.html
JM
This sandbox is not long in use, and was replaced with newer versions. Please see https://developer.cisco.com/sdwan/
Hope this helps!
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thank you. yes this very helpful.
Password and user details have been reset by the ENG team. To access the shared environment and start developing, please follow these steps:
  1. Go to https://sandbox-sdwan-1.cisco.com
  2. Login with credentials [devnetuser/RG!_Yw919_83]
