I can not see storage added
Joel Mfunga
Hi everyone, i have thow problemes
1. I can not see the storage added
2. Vmanage runs and after 5 sec shutdown.
Please help me or guide me.
shambhu.kumar
Hello Joel,
Please delete it and re-create using below CLI
1-  mkdir /opt/unetlab/addons/qemu/vtmgmt-20.7.1
2-  Copy file into folder using winzip/filezila
3-  cd /opt/unetlab/addons/qemu/vtmgmt-20.7.1
     mv viptela-vmanage-20.7.1-genericx86-64.qcow2 virtioa.qcow2
4-  /opt/qemu/bin/qemu-img create -f qcow2 virtiob.qcow2 100G
5-  cd
 /opt/unetlab/wrappers/unl_wrapper -a fixpermissions
please assigned 24 GB RAM at least.
Shambhu Kumar
5 Replies 5
Torbjørn
Can you see the file in your appliance folder if you run the following?
ls -ahl /opt/unetlab/addons/qemu/vtmgmt-20.7.1
It could be an issue with permissions. Run the following command to see if it makes a difference
You should also make sure to wipe the node after making changes to the appliance folder for the changes to take effect in your lab.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
I have done what you asked me but Vmanage can not run
shambhu.kumar
Hello Joel,
5-  cd
Shambhu Kumar
Thank you Kumar. I will try it tomorrow I am at work at this time.
Hi Sir, i have assigned 24GB of RAM to Vmanage but it is doing the same things, means boot and shutdown but when i reduce it to 4GB it boots but nothing is going on...
