OMP doesn't come up
michael1999ac
Hi Everyone,
I have I problem with my SD-WAN topology. I can get any OMP peers between vEdges, what should I do?
Here is the output
yeah that was the problem, I forget about the default route on the vSmart, thank you guys for your help,
BTW, I also recommend to others that routes will no be shared between sites if they have the same site-id, it also happens to me
Thank you!!!
6 Replies 6
Sorry there is no topology
Can you reattach it
MHM
most probably you don't have control connection from vedge to vsmart and thus no overlay routing.
Verify with "show control connections" on vedge devices.
HTH,
OMP not see in Edge
1- there is no connection between edge and vsmart
 show control connections-history
2- vsmart not see other edge
vsmart1# show omp peers
 3- the vsmart use policy deny all OMP router to your edge site-id
check in vsmart the policy you apply
MHM
Thank you!!!
You are so so welcome
MHM
You are welcome. The same site-id is expecting behaviour:
https://community.cisco.com/t5/sd-wan-and-cloud-networking/service-vpn-and-omp-connectivity-issue/td-p/4844072
HTH,
