Remove tunnels with old color - Cisco SDWAN
Networx-nerd
Hi All,
I need some assistance in understanding on removing tunnels previously created with "Default" color and now changed to any other color? After changing the color, the tunnels (showing from the SDWAN Sites (default color) to other sites ) are showing down and there is no option to clearly remove those or clear those.
Default color is not in use anymore but somehow its stuck to the monitor screen and need assistance to get rid of those stale entries.
dijix1990
Which version do you use? When I have controllers version 20.7.1 I had the same problem. Alert go away only in a day. Now my environment with 20.9.4.1 and I've checked changing color, old one clear immediately
