route leaking between vpn's via topology
dijix1990
I have router leaking between vpn's via topology - action "export to"
leaking between VPN1 (HUB DC) and VPN's 10-11,13,15 (BRANCHES)
  vpn-list VPN-export-from-Branch-to-DC
   vpn 10-11
   vpn 13
   vpn 15
  vpn-list VPN-export-from-DC-to-Branch
   vpn 1
  vpn-list VPN-import-to-Branch
   vpn 10-11
   vpn 13
   vpn 15
  vpn-list VPN-import-to-DC
   vpn 1
 control-policy Topology-vpn-export-from-DC-to-branch
    sequence 1
     match route
      prefix-list _AnyIpv4PrefixList
     action accept
      export-to vpn-list VPN-import-to-Branch
  default-action accept
 control-policy Topology-vpn-export-from-branch-to-DC
    sequence 1
     match route
     action accept
      export-to vpn-list VPN-import-to-DC
  and it's working as usual. Some days ago I wanted to add new sequence for VPN16 but for new sequence 11 it doesn't work.
    sequence 1
     match route
     action accept
    sequence 11
     match route
     action accept
      export-to vpn-list VPN16-Branch-WiFi
    sequence 1
     match route
     action accept
    sequence 11
     match route
     action accept
Why it happens? can't I use some sequences for leaking? If I add vpn16 to vpn lists VPN-export-from-Branch-to-DC and VPN-import-to-Branch leaking works
Mmmm OK @dijix1990
So, you need to adjust the configuration to avoid overlapping matches in sequence 1 and sequence 11.
One approach is to use more specific criteria in sequence 11, such as a dedicated vpn-list or prefix-list for VPN16, ensuring it does not overlap with VPN1 routes processed in sequence 1.
Alternatively, you can split the handling of VPN1 into separate vpn-lists, one for VPN10-11,13,15 and another for VPN16, ensuring each sequence has its own distinct route set to process. This will ensure that sequence 11 gets evaluated for VPN16-specific traffic without interference from sequence 1.
Best regards
5 Replies 5
M02@rt37
Hello @dijix1990
Control policies process sequences in the order they are configured. If a route matches the criteria in an earlier sequence, the corresponding action is executed, and subsequent sequences are ignored.
So, in your case, routes matching sequece 1 in the Topology-vpn-export-from-DC-to-branch policy are handled there, so they do not reach sequence 11. This behavior is expected in policy-based configurations.
Additionally, the problem arises because vpn16 is not explicitly included in the VPN-export-from-Branch-to-DC or VPN-import-to-Branch lists. As a result, vpn16 does not match the export-to operation unless it is specifically added to the vpn-list used in sequence 1. If the VPN lists in sequence 1 already handle routes intended for vpn16, adding a new sequence for it will not work unless the sequence logic is adjusted.
When you add vpn16to existing VPN lists like VPN-export-from-Branch-to-DC and VPN-import-to-Branch, it becomes part of the matching process in sequence 1. Therefore, the export-to action works without needing a separate sequence for vpn16. This approach works because the route-leaking logic applies to all VPNs in the lists, including vpn16.
You need to adjust the matching criteria in the new sequence. This can involve using a specific vpn-list for vpn16 that does not overlap with the lists used in sequence 1. You can also modify the prefix-list or ensure that vpn16 routes do not match earlier sequences. By doing so, vpn16 can be processed independently without being handled by sequence 1.
Best regards
it's strange logic, because it's not the same sequence
Vpn 10-11,13,15 + vpn 1
And
Vpn 16 + 1 vpn
For me it's not normal logic, matches criteria is different
For data policy I can use different sequences and it works correctly
Mmmm OK @dijix1990
Best regards
Sorry why you use term leaking ?
leaking is done in same router, in SDWAN between two peers there is no leaking
VPN x - OMP - VPN y
OMP how can I called it universal, for which we can receive prefix from different VPN
and for issue try change the order
MHM
It the same process, it happens on the vSmart, all prefixes from one vpn export to another vpn
