12-31-2024 01:29 AM
I have router leaking between vpn's via topology - action "export to"
leaking between VPN1 (HUB DC) and VPN's 10-11,13,15 (BRANCHES)
vpn-list VPN-export-from-Branch-to-DC
vpn 10-11
vpn 13
vpn 15
vpn-list VPN-export-from-DC-to-Branch
vpn 1
vpn-list VPN-import-to-Branch
vpn 10-11
vpn 13
vpn 15
vpn-list VPN-import-to-DC
vpn 1
control-policy Topology-vpn-export-from-DC-to-branch
sequence 1
match route
prefix-list _AnyIpv4PrefixList
action accept
export-to vpn-list VPN-import-to-Branch
default-action accept
control-policy Topology-vpn-export-from-branch-to-DC
sequence 1
match route
action accept
export-to vpn-list VPN-import-to-DC
and it's working as usual. Some days ago I wanted to add new sequence for VPN16 but for new sequence 11 it doesn't work.
sequence 1
match route
action accept
sequence 11
match route
action accept
export-to vpn-list VPN16-Branch-WiFi
sequence 1
match route
action accept
sequence 11
match route
action accept
Why it happens? can't I use some sequences for leaking? If I add vpn16 to vpn lists VPN-export-from-Branch-to-DC and VPN-import-to-Branch leaking works
Solved! Go to Solution.
12-31-2024 10:08 AM
Mmmm OK @dijix1990
So, you need to adjust the configuration to avoid overlapping matches in sequence 1 and sequence 11.
One approach is to use more specific criteria in sequence 11, such as a dedicated vpn-list or prefix-list for VPN16, ensuring it does not overlap with VPN1 routes processed in sequence 1.
Alternatively, you can split the handling of VPN1 into separate vpn-lists, one for VPN10-11,13,15 and another for VPN16, ensuring each sequence has its own distinct route set to process. This will ensure that sequence 11 gets evaluated for VPN16-specific traffic without interference from sequence 1.
12-31-2024 08:42 AM
Hello @dijix1990
Control policies process sequences in the order they are configured. If a route matches the criteria in an earlier sequence, the corresponding action is executed, and subsequent sequences are ignored.
So, in your case, routes matching sequece 1 in the Topology-vpn-export-from-DC-to-branch
policy are handled there, so they do not reach sequence 11. This behavior is expected in policy-based configurations.
Additionally, the problem arises because vpn16 is not explicitly included in the VPN-export-from-Branch-to-DC
or VPN-import-to-Branch
lists. As a result, vpn16 does not match the export-to operation unless it is specifically added to the vpn-list used in sequence 1. If the VPN lists in sequence 1 already handle routes intended for vpn16, adding a new sequence for it will not work unless the sequence logic is adjusted.
When you add vpn16to existing VPN lists like
, it becomes part of the matching process in sequence 1. Therefore, the export-to action works without needing a separate sequence for vpn16. This approach works because the route-leaking logic applies to all VPNs in the lists, including vpn16.
You need to adjust the matching criteria in the new sequence. This can involve using a specific vpn-list for vpn16 that does not overlap with the lists used in sequence 1. You can also modify the prefix-list or ensure that vpn16 routes do not match earlier sequences. By doing so, vpn16 can be processed independently without being handled by sequence 1.
12-31-2024 08:56 AM
it's strange logic, because it's not the same sequence
Vpn 10-11,13,15 + vpn 1
And
Vpn 16 + 1 vpn
For me it's not normal logic, matches criteria is different
For data policy I can use different sequences and it works correctly
12-31-2024 10:08 AM
Mmmm OK @dijix1990
01-02-2025 02:55 AM
Sorry why you use term leaking ?
leaking is done in same router, in SDWAN between two peers there is no leaking
VPN x - OMP - VPN y
OMP how can I called it universal, for which we can receive prefix from different VPN
and for issue try change the order
MHM
01-02-2025 09:53 AM
It the same process, it happens on the vSmart, all prefixes from one vpn export to another vpn
