SD-WAN Device Failures
Hi Guys,
I have a doubt regarding network device failures. If a network device goes down, the up-links (incoming link and out going link) should be bridged and the network functions should work without any issues. How do we call this mechanism?
Senthu
5 Replies 5
gneslim
Are you referring to the terms "Fail to wire" or "Fail Open"?
Explanation: The LAN-WAN connection becomes a straight-through connection if the transit appliance is going through hardware or software failure.
Yes. "Fail Open". Is it support in SD-WAN solution?
Senthu
I believe the fail-to-wire feature is currently not available in the Viptela-based SD-WAN solution.
Simon Ko
I think only transparent devices can do this.
ASA on wire mode and Riverbed in Fail-to-wire , I believe, can be taken out of packet path.
Since device failed, unless it is designed as such, there is no managing process to put ports into a bridge group.
But, I think it can be done.
Their answer is buy two!
There is no such feature in Cisco SD-WAN.
