Upgrade SD-WAN Controller from 20.12.3 to 20.12.4.1
dimdim12
I will upgrade my SD-WAN controller from version 20.12.3 and 20.12.4.1. I upgrading because it is currently hitting several open bugs, my concern is
- Is there any upgrade path information related to upgrading from version 20.12.3 to 20.12.4.1? because in this link https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/controllers-20-12/rel-notes-controllers-20-12.html doesn't explain it. I need official documentation from Cisco
Thank you
Torbjørn
This upgrade would "only" be a patch as both releases are within the same minor release. There should not be any form of breaking changes between these versions, there is hence no upgrade path information.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hi !
In this URL, You can check vManage Upgrade Path. (It is same for cEdge, vSmart, vBond as well.)
