Vbond connection is temporary or permanent
MAHI_VYAS
Hi all,
Previously in sdwan version 17 or 18.X i observed edge routers having vbond temporary connection and when vsmart/vmanage connections established we wont see vbond connections anymore.
Now iam running 20.12.4 and in this version i see we are having permanent connections from edge router to vbond as well.
can anyone explain why this behaviour.
It temporally.
But if you have one smart and by defualt max- connect is 2 then it will be permanent.
Only change max-conn to be 1 and it will be end
Later you can see it in history
MHM
Hi @MHM Cisco World ,
Can you please explain were I need to change max control connection ( on vsmart or vbond or vedge routers ).
I would be great if you explain why this behaviour.
