vEdge 100 - How to use GPS?
AngryEyebrows
I have my first vEdge 100 in my SD-WAN mesh and I am wondering how to use my GPS?
When I use the command line I do not see any options with gps-location to use anything other than latitude/longitude...
Does it auto-update if I do not manually specify the GPS?
I'm starting to think that even though the vEdge 100b has a GPS antenna, it is not actually working and can only be used with vEdge models that have cellular (vEdge 100m, vEdge 100wm)...
    That is correct.
Cristian Matei.
