06-13-2019 01:00 AM
I have problem with add vEdge to vManage. Status on vManage is up and down sequence. And when i show on vedge " Show control connection-history " have fault : RXTRDWN/DISTLOC. So how can i fix this ?
Solved! Go to Solution.
06-14-2019 01:07 AM
06-14-2019 01:07 AM
06-14-2019 06:54 AM
Thanks u.
12-17-2020 03:14 AM
I got a similar issue on a vEdge, control connection UP/DOWN constantly, the software version of the vEdge was to old and not compatible with vManage version, once i did an upgrade to a supported version the problem was fixed.
