vEdge Upgrade via USB
I have a few vEdges in the warehouse that i would like to update before sending them to the remote site, i would like to download the OS image in a USB flash drive and connect it via the USB port in each vEdge, is there a guide for doing this?.
I need to use the command "request software install /directory-path/", i tried with a vEdge5000 and it took me a while to be able to upgrade it from the USB, as far i can tell the Linux subsystem mounts the USB drive when connected to vEdge 1000 the usb is drive is not recognized.
9 Replies 9
David Aicher
you probably need to enable the usb controller on the vedge1k
enter the following config
system
   usb-controller
Be aware this will reboot the vedge.
to verify the controller is enabled
vedge# show running-config system usb-controller
system
  usb-controller
once the controller is enabled you should be able to see the usb drive when it is plugged in.
Thanks David, yes i enabled the usb-controller but for some reason it
didn't recognized the USB stick, i make it work in a vEdge5k when the USB
stick was connected i was able to see the files included in the USB by
using FILE LIST where it showed the USB Stick with the path "/media/sdb1"
and i could upgrade the vEdge with " request software install
/media/sdb1/filename", do you know the file path on a vEdge1000 when
connecting a USB?
try df -h from vshell.  If the memory stick is recognized it will show there.
Thanks! i will try this morning and post the results.
I was able to upgrade a vEdge 1000 via the USB port, after i applied the
"usb-controller" command and a reboot the vEdge was able to recognize and
auto-mount the flash drive, funny enough i have to use different flash
drives as one of them wasn't recognized.
A handy vShell command that worked for me was "mount" that showed me the
path that i needed to use for the "request software install", in my case i
tried in 2 vEdges 1K and in one case it was recognized as "/dev/sdb1" so i
had to run "request software install /media/sdb1/viptela-xxx-mips64.tar.gz"
and in the other vEdge as "/dev/sdc1"
Hello David.  When attempting the commands listed it goes into system config mode, I received a "syntax error".. on version 20.6.1.1 trying to migrate to 17.06.03a.
Simon Ko
The only way you will get this to work is via tftp: or ftp:
plug mgmt0 into network with dhcp.
under vpn 512, int mgmt0, ip dhcp-client, commit
exit out
 request software install tftp://x.x.x.x/viptela-19.2.2-mips64.tar.gz vpn 512
 request software set-default 19.2.2
 request software activate 19.2.2
Now you are upgraded.
Thanks for the info, it worked for me using the USB, although i had to
upgrade a vEdge100m using a TFTP server connected to one of the ports
configured in VLAN1.
asif.ahmed1
Upgrade the IOS
To upgrade the IOS download the correct IOS on to a USB.
On the Vedge type the following commands:
conf t
system
usb-controller
Please reboot the Vedge
Once the device comes back type the following command
file list /media
This tells you which directory the ios is in (in my case it was sda1) it can be sdb1 or sdc1 etc. Type the following command
request software install-image /media/sda1/viptela-20.3.3.0.4-x86_64.tar.gz
request software activate 20.3.3.0.4
yes to confirm and reboot
