03-13-2024 12:46 PM
I have SDWAN lab (Vmanage, vsmart, vbond) after the initial configuration I installed certificates on all controllers, but I have a problem, when do show control connections , nothing was shown. nd when do show orchestrator connections on Vbond nothing shown, don't have an idea about this issue, indeed to help to set up the lab.
Can you see the pictures below>
Thanks.
Solved! Go to Solution.
03-13-2024 01:54 PM - edited 03-13-2024 01:54 PM
I suspect that you might be missing tunnel-interface configuration. Can you post the configurations of the controllers?
03-13-2024 04:35 PM - edited 03-13-2024 04:35 PM
As you mentioned the Lab is this virtual Lab ?
try reload all the device in order and check ? turn off all, start vmanage, vbond, vsmart
have similar lab works as expected, i had faced same issue reboot the device has fixed the issue : (if the configuration correct)
https://www.balajibandi.com/?p=2028
03-15-2024 03:09 PM
share show control local-properties from vmanage/vsmart and show orchestrator local-properties from vbond.
03-19-2024 03:01 PM
03-21-2024 12:53 PM
03-22-2024 06:33 PM
Please give me what I must configure the tunnel interface on all controllers,.
03-23-2024 03:22 AM
i may have lost this thread - what is the issue ? you not able to see vbond show connections ?
03-19-2024 03:01 PM
03-15-2024 03:09 PM
03-19-2024 03:03 PM
03-23-2024 03:51 AM
I confused, did you solve the problem?
If not, clear control connection history by "clear control connection-history" wait for 5minutes and then provide show control connection-history from all controllers (for vbond use orchestrator keyword)
