03-03-2023 08:58 PM - edited 03-03-2023 09:06 PM
Hi Please see the below. The device below is one of the vEdges. but why this one does not show vSmart connection? Thank you
03-07-2023 03:13 PM
it can be lots of possible reason..
Do you have control connections between vsmart and vbond/vmanage? And check for an issue with "show control connection-history" on vedge
HTH,
03-08-2023 07:10 PM
Thank you for your reply!
What command can have control connections between vsmart and vbond/vmanage?
03-08-2023 08:47 PM
show control connections on vSmart/vManage
show orchestrator connections on vBond
Below guide is very helpful for troubleshooting of control connections:
HTH,
03-09-2023 07:46 PM - edited 03-09-2023 07:50 PM
Thank you very much for your reply!
In vBond, "show control connection / show orchestrator connection" show nothing. certificates installed successfully. why it cannot show any connection?
03-10-2023 07:56 AM
Use show orchestrator connection-history to understand the error in communications.
You can use show control connection-history from vmanage/vsmart as well.
