ShamilaGul58174
Visitor
the Cisco CPN Client for a long time to connect to a VPN Server. Now I've got a new machine with a Windows 7 64 bit. The Cisco VPN Client isn't avaiable in a 64 bit version. Cisco suggests to use Cisco AnyConnect instead because there'a 64 bit version avaiable. The problem: When I use AnyConnect on my new machine, I always get a timeout when I try to connect. So I've installed AnyConnect on the old machine for testing and there I get the same problem: connection timeout. When I use the CPN Client, everything works fine. How can I fix this problem?
3 Comments
