dhr.tech1
Lab Topology:
As you can see below, user David prefers to connect to LAN over EAP-TLS, but Simon prefers to connect over the LAN using PEAP.
User David
Configured to use EAP-TLS based authentication.
User Simon
Configured to use PEAP Authentication
Authentication Setting
  • We need to integrate Active Directory with Cisco ISE, as shown below, for PEAP authentication.
  • We also need to setup Certificate based Authentication for EAP-TLS Users
  • The most important part to allow both EAP-TLS and PEAP to operate together is to perform below step.
ISE Policy configuration
  1. Setup Authorisation profile, which will enable pushing Dynamic VLAN into the Cisco IOS switch for both EAP-TLS and PEAP Users.
2. Authentication and Authorisation profiles
  • Create a new policy set.
  • Create a single authentication policy for EAP-TLS and PEAP
  • Create Authorisation Policy.
Verification
1 Comment
Martin L
Thank You for sharing the insightful information!
