Panos Kampanakis
Under construction
Introduction
Logging in high performance environments is non-trivial. NetFlow on the ASA provides an efficient way to track connection creation, teardown and denies in an efficient manner. This is done by sending binary data in UDP packets as opposed to ASCII based syslog messages. The implementation used on the ASA platforms is NetFlow v9 which is defined by RFC3954
The feature was introduced in ASA 8.2.1/ASDM 6.2.1. For information on the feature itself, its functionality and limitations you can read here. The document below presents how to use ASDM to configure the ASA to send Neflow information to the Netflow collector.
Configuration
Configure the Collector
In ASDM under Configuration go in Device Management > Logging > Netflow.
There you can set the Netflow collector ip address, the ASA interface it is behind and the port it supports.
You can also set the template packet send frequency and disable syslogs that are redundant after the Netflow information extraction.
Configure the Netflow information extraction
To enable the ASA to start sending information to the collector defined above you need to go to Firewall > Service Policy Rules.
You create a new service policy that needs to be applied GLOBALLY.
Define the traffic that you need to collect Netflow statistics for.
And then define the collector that statistics for this traffic will be sent to (that you defined above).
Finally, you have a Netflow service policy on your ASA.
Finalized configuration
After deploying these changes to the ASA, you configuration for the feature should looke like this.
access-list global_mpc extended permit ip any any
flow-export destination inside 192.168.1.13 2055
class-map global_class
  match access-list global_mpc
policy-map global_policy
  class inspection_default
   inspect dns migrated_dns_map_1
     inspect ftp
     inspect h323 h225
     inspect h323 ras
     inspect netbios
     inspect rsh
     inspect rtsp
     inspect skinny
     inspect esmtp
     inspect sqlnet
     inspect sunrpc
     inspect tftp
     inspect sip
     inspect xdmcp
     inspect icmp
  class global_class
   flow-export event-type all destination 192.168.1.13
Eduardo Camio
Which asa and asdm software version support this feature?? I'm already running 8.0.4 and 6.1.5 respectively and is not present.
Thanks in advance.
Panos Kampanakis
The feature was introduced in ASA8.2.1/ASDM6.2.1.
So you would need to upgrade.
jakewilson
We have been getting a few calls with questions on the uniqueness of the NetFlows exported by the Cisco ASA. Check out this PDF:
http://www.plixer.com/files/netflow-on-the-asa-11-18-09.pdf
c.pangkerego
Not sure if this is matter or not but if we're following the pictures, there's a few typos.
It should say:
class-map global-class NOT class-map global_class
class global-class NOT class global_class
santiago.jem
Hi Gio,
May I know what is the ideal netflow analyzer for the Cisco ASA?
The one you're using or you would recommend. Hope it's free!
Hoping to hear from you soon.
Thank you.
Alcides Miguel
How do I do to cisco ASA export the interfaces names instead of ifindex? and also export the appliance name?
Best regards,
Alcides
jakewilson
The Cisco ASA will not export an interface option template using NetFlow like IOS.  The only way to get those interface names is via SNMP which is what most NetFlow solutions use to get them.
semills
Community Member
I followed the Configuration above and it works on my ASA that do not have AnyConnect configured on them.  But the ASA with AnyConnect configured do not send data to the Netflow collector.  Below is the sh flow-export counter from one of the effected ASA.  As you can see the collector is pingable.
Lokasa5520# sh flow-export counters
destination: inside 10.89.0.20 2055
  Statistics:
    packets sent                                          5173026
  Errors:
    block allocation failure                                    0
    invalid interface                                           0
    template send failure                                       1
    no route to collector                                       1
Lokasa5520# ping 10.89.0.20
Sending 5, 100-byte ICMP Echos to 10.89.0.20, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 100/104/110 ms
Lokasa5520#
walter baziuk
Level 5
Level 5
i have it configure on our 5506x with SF module
how do i configure the FMC VM GUI to accept the netflow
how do i tell it to accept  the port specified sent from the asa and rtr?
Kuat Bakenov
example change 514 port to 8888
     logging host dmz 1.1.1.1 1/8888
bbiandov
excellent guide - Thank you! The ASA is a perfect netflow sensor right out of the box!
How do I configure the flow export to send source MAC address as well?
Supposedly, this is a feature of Flexible NetFlow.
strosale@cisco.com
Access-list [aclname] extended permit ip any any
class-map [name"A"]
  match access-list [aclname]
   class [name"A"]
         flow-export event-type all destination [collector]
