9134 and Inter VSAN Routing
stewart699700
Can a Fabric Switch such as the 9134 do Inter VSAN Rouring (IVR)?
The 9134 supports VSANs but can it be configured for IVR or would this be done on another device.
Stewart
calopez2
Hi Stewart,
IVR is not supported on the Cisco MDS 9134 Fabric Switch
Please see here.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_0/configuration/guides/ivr/nxos/ivrbasic.html
You will need to enable IVR on another supported switch, as needed.
Carlos
calopez2
Hi Stewart,
Please see here.
Carlos
Thanks Carlos,  Much appreciated.
Stewart
