cache engine overloads, how to.....
m_aurangzeb
i've cisco cache engine 505 attached with cisco 2611 router. Now whenever i reload my cache engine it performs its job for 5 minutes after that it overloads and cannnot perform its job and cache engine changes its state to bypass mode.
What could be the factors that causes this problem?
How can i avoid this problem.
this could be memory issue? if yes then which memory.hardisk or RAM or else?
pls reply me as soon as possible.
Not applicable
The ICAP daemon on the Content Engine continues to send updates (from the HTTP response) to the ICAP server, and it overloads the cache engine
