Changing system default switchport in running system
lasse.birnbaum
I have a setup using Nexus 5K with 2K fexes. Default switchport state is active. I would like to change this with the command:
 system default switchport shutdown
Im not sure what will happen to all the currently active ports - i cannot find any documentation where this is explained.
Have any of you done this ?
Or have anybody seen documentation about this ?
Best regards
Lasse
Mark Malone
Looking at the below they will all change so you might want a window running a command like that
To configure all Layer 2 switchports to be Layer 3 routed ports, use the system default switchport shutdown command. To reset to the default of all Layer 2 swithports, use the no form of this command.
no system default switchport shutdown
Syntax Description
This command has no arguments or keywords.
Command Default
The default is all ports configured as Layer 2 switchports.
Command Modes
Global configuration mode
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/command/reference/interfaces/N5k_if_cmd_ref/n5k_if_cmds_s.html#pgfId-2709418
Mark Malone
Syntax Description
Command Default
Command Modes
I would also like to remove the "system default switchport shutdown" to make my Nexus 9K ports Layer 2 by default.
Does anyone know if this is disruptive or what effect it will have to L2 and L3 interfaces already configured?
Jim
