Configure LAG LACP between two NX5K VPC and two clustered Juniper SRX FW
hbaytie01
I need the best recommendation to configure the LACP between the two 5Ks and the clustered SRX.
What i did is i created on both 5Ks a single port-channel 501  and I added to it the VPC 501. Under two interfaces from each 5K, i configured it to be channel-group 501 mode active.
On the Juniper side, i have four ports as reth0 and the below is the configuration:
set interfaces xe-0/0/18 description “Servers-interface-to-Primary 5K”
set interfaces xe-0/0/18 gigether-options redundant-parent reth0
set interfaces xe-0/0/19 description “Servers-interface-to-Primary-5K”
set interfaces xe-0/0/19 gigether-options redundant-parent reth0
set interfaces xe-7/0/18 description “Servers-interface-to-Secondary-5K”
set interfaces xe-7/0/18 gigether-options redundant-parent reth0
set interfaces xe-7/0/19 description “Servers-interface-to-Secondary-5K”
set interfaces xe-7/0/19 gigether-options redundant-parent reth0
set interfaces reth0 redundant-ether-options redundancy-group 1
set interfaces reth0 redundant-ether-options lacp passive
set interfaces reth0 redundant-ether-options lacp periodic slow
Now the four interfaces are directly connected but I'm not able to make them ping each other from their sub-interfaces, i want to know if it is a firewall issue taking into consideration everything is allowed or if it is an LACP problem. what kind of command I can use to verify the LACP connection is working from the 5K side.
Thanks in advance
Rick1776
Level 5
Level 5
There are several ways to check the LACP paremtetes
switch# show lacp { counters | interface type slot / port | neighbor | port-channel | system-identifier }
Is the port channel up with the member ports?
Can you show the output from
Show po summary
Show LACP neighbors
