Connect between with two VWIC-1MFT-G703 module?
jiangcy
I has three router which has VWIC-1MFT-G703 modules.I want to connect each other with RJ45 UTP e5 cable.I has notice that pinout of the RJ48c.
I can configurate one E1 port "clock source internal".
Do the connection set up?
thomas.chen
Level 6
Level 6
Yes, one end would be internal and other end should derive the clock from line to ensure sync.
