Connecting 4 Nexus 2000 with Nexus 7000
conceptzone
Hi ,
I have two N7K-F248XP-25  going to be installed in one Nexus 7009 and I have 4 N2K-C2248TP-1GE (48x100/1000-T+4x10GE) .
In simple way, I have two F2 line cards within one N7K and 4 N2Ks. The N7K will be used as a parent switch and it has NX-OS version 6.0
So I want to connect the 4 N2K to the two F2 line cards in a redundant fasion, can some one tell me the best practice of how to connect those N2Ks?
I have read somewhere that I can only use two ports from each 4 shared ports but I am not sure if this is true. I will appreciate any input or a link.
krun_shah
Here you go
http://www.netcraftsmen.net/component/content/article/69-data-center/1284.html
That was Awesome link! Thanks indeed.
So can you please confirm if I am following the F2 + FEX rule
Again, I have only one Nexus 7009 and 4 x N2K , so I have two F2 cards on the Nexust 7009. Here is my connectivity plan:
1st N2K to port 1 on the first F2
1st N2K to port 1 on the second F2
2nd N2K to port 2 on the first F2
2nd N2K to port 2 on the second F2
3rd N2K to port 3 on the first F2
3rd N2K to port 3 on the second F2
4rth N2K to port 4 on the first F2
4rth N2K to port 4 on the second F2
So eventually , I am planning to use one group (4 ports) on each F2 card for all the connectivity to those N2K Switches.
Also, I will have a total of 4 port channels .. right ? 1 Port channel for each N2K
I will appreciate your feedback!
Yes this looks good design with redundancy. It also follows all F2+FEX rules.
Thanks indeed Krun for the feedback. So i have been asked to increase the redunandcy a little bit and here is what I am going to do with those 4 switches : (Please let me know if I am again following the F2 + FEX rule)
Ismail
