connecting ethernet to token ring
aborres
Level 2
Level 2
I'm having trouble trying to configure cisco 2612 router to connect SNA server to datacenter host. please refer to connectivity below.
SNA server--eth----router--t/r--control unit--modem-SDLC---modem---FEP
the controller unit has token ring card installed on it and it's connected to router's t/r port..i configured the router with SR/TLB but no success, what we did we temporarily removed the router and add token ring adapter on the same SNA server then connect direct to control unit and it's work but we need to implement the connectivity shown above..thanks
11 Replies 11
mbinzer
a very simple question. What dmac did you use on the sna server when it was ethernet attached?
If you say it works with a tokenring adapter what damc was used in this example?
You need to bitswap the dmac when you have the sna server ethernet attached. Some do try always both canonical and non-canonical, some dont.
Do you have a chance to take a sniffer trace on the tokenring when you try to do sr/tlb to see what frames are beeing exchanged between the sna server and the tr controler.
The only other point you may need to look at is the mtu size. If you connect an ethernet like described above your mtu on the ethernet is limited to 1500. So make sure that the tokenring router and control unit are ok with that.
Also the configuration you used and the ios version on the cisco2600 would help to get some more ideas what might go wrong.
thanks...
Matthias
Hi Matthias,
I did bitswapped the dmac configured on the SNA server from 400013052100 to 0200C8A08400 but the same problem (connection pending), is there any tools or utility wherein we can check whether our router is forwarding DLC protocol to the control unit or not.
Thanks;
Ador
debug source error
debug source event
debug source bridge
Also a sniffer on the tokenring should show you what goes on.
If you dont have a sniffer take a look at ethereal:
http://www.ethereal.com/
it is free and works very well.
Besides that i would advice to open a case with cisco tac and work the issue in detail. This is supposed to work and if it does not work than we need to find out why.
thanks...
Matthias
Hi Matthias,
Thanks for the reply, one more thing, I got utility to ping the dmac from ethernet station..result is shown below.
Sending TEST Commands to NIC MAC 400013052100
Request timed out after 500ms
Test Commands were not acknowleged
Flipping MAC bits. New MAC is 0200C8A08400
Reply from 0200C8A08400: time <0ms
Sent 4, Received 4, Lost 0 (0% Loss)
please advise if the above ping result is normal or not...
Ador
Hi Ador,
i dont know the tool you are using but if that result is correct than it seems as if the "ping" goes through when you use the ethernet format mac address. That would indicate that the router is forwarding those frames in both directions.
It looks like as if you are sending sna test frames with your ping utility and you expect a test final or something back.
I think the best way to go on is to take a sniffer on your tokenring and see what comes and goes and then try your ping utility, have a look how it looks and try a login from your server.
thanks...
Matthias
Hi Matthias,
please check the attached captured frames using ethereal. we are still facing problem connecting sna server using ethernet..
Ador
based on the prior conversations i assume the following topology:
So in case of your tokenring attached sniffer trace i think the server was tokenring attached instead of ethernet.
I assume that the sniffer was always in the "right" tokenring based on above topology.
In both traces there are no rif fields in the sna frames from and two the sna server. I filtered for
4000.1305.2100.
I would assume always to see a rif field in the frames on the right tokenring.
In the first, the working case, when the client is on tokenring you should have source bridging configured and then we certainly would see a rif field.
In the case when the client is ethernet attached you should have sr/tlb configured and we would then also see a rif field in the sna frames.
Are you simply doing transparent bridging between those two tokenrings and then also between the ethernet and the tokenring?
I guess we will need to look at your currnet configurations first to understand how this is currently configured.
It is most likely also a good idea to open a case with the tac at that point.
thanks...
Matthias
Hi Matthias,
working topology:SNA server with 2 NIC ethenet and T/R
--eth-SNA-t/r---control unit-modem--sdlc--modem--FEP
with router:not working
SNA-eth-router-t/r-control unit-modem-sdlc-modem-FEP
please checked the router config below, thanks
Current configuration : 686 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
enable secret 5
ip subnet-zero
no ip routing
source-bridge ring-group 20
source-bridge transparent 20 10 2 5
interface Ethernet0/0
ip address 10.10.50.2 255.255.255.0
no ip route-cache
bridge-group 2
interface TokenRing0/0
no ip address
no ip route-cache
ring-speed 16
source-bridge 5 2 20
ip default-gateway 10.10.50.1
ip classless
ip http server
bridge 2 protocol ieee
bridge 2 bitswap-layer3-addresses
line con 0
line aux 0
line vty 0 4
password
login
Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 000e.3853.fae0 (bia 000e.3853.fae0)
Internet address is 10.10.50.2/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
3789 packets input, 364786 bytes, 0 no buffer
Received 2964 broadcasts, 0 runts, 0 giants, 0 throttles
354 packets output, 39668 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
TokenRing0/0 is up, line protocol is up
Hardware is HAWKEYE, address is 0070.1cca.5f87 (bia 0070.1cca.5f87)
MTU 4464 bytes, BW 16000 Kbit, DLY 630 usec,
Encapsulation SNAP, loopback not set
ARP type: SNAP, ARP Timeout 04:00:00
Ring speed: 16 Mbps
Duplex: half
Mode: Classic token ring station
Full duplex capable
Source bridging enabled, srn 5 bn 2 trn 20 (ring group)
spanning explorer disabled
Group Address: 0x00000000, Functional Address: 0x0800011A
Ethernet Transit OUI: 0x000000
Last Ring Status 00:05:14 (0x2000)
Last input 00:00:00, output 00:00:03, output hang never
5 minute input rate 1000 bits/sec, 1 packets/sec
2794 packets input, 449251 bytes, 0 no buffer
Received 962 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
390 packets output, 31117 bytes, 0 underruns
0 output errors, 0 collisions, 8 interface resets
0 transitions
i think your sr/tlb statement is not correct:
you have configured:
20 is the source bridge virtual ring group
10 is the pseudo ring, this is the ring number used
to represend the ethernet from the tokenring
2 is the bridge number between 20 and 10
5 is the transparent bridge group tied into the
source bridge environment
however you dont have a transparent bridge-group 5. You have transparent bridge group 2.
your statement should look like this:
source-bridge transparent 20 10 2 2
additional i would add under the tokenring interface
the command:
source-bridge spanning
just in case your end systems are sending single route explorers. If they do you must enable the tokenring inteface to accept single route (spanning tree) explorers.
thanks...
Matthias
Hi Matthias,
from the attached show lnm station and show source-bridge. 4000.1305.2100 is the dmac configured on SNA server when it is connected thru token ring and it has t/r mac 4000.1305.2102. when connected thru ethernet, I did bitswapped the dmac to 0200.C8A0.8400 but still giving connection pending, is there any required modification at the host side if we want to connect the SNA server thru ethernet?
thanks,
Ador
in general the host does not know on what meadia you are. Unless you have some sort of a dialout configuration the host normaly does not have any mac address knowledge about the client.
If i assume that the sr/tlb statement is correct, and you can see the correct addresses in the transparent bridge table from the ethernet end and also in the source-bridge environment.
show bridge
show source
show rif
than i guess you are back to use a sniffer and see if you get any communincation between those two devices and if so how far you get.
You should see frames with a rif field going from and to the configured pseudo ring when you look at it from the tokenring perspective.
Is your tokenring/sdlc converting device understanding rif's?
I am a littlebit out of idea's right now.
thanks...
Matthias
