DLSw Backup Problem with two connection to the IBM Host
mchakir
Hello EveryOne,
I'm Mostafa Chakir from morroco, Project engineer for a DLSw Installation using four Cisco boxes.
In the central site, we are installing two cisco routers for IBM Host attachement with CPA Card, and the two others are used for WAN connection to remote sites.
# IBM Host #
# CPA1# # CPA2 #
# WAN1# # WAN2 #
The remotes sites are connected to the WAN1 and WAN2 (50%, 50%) via FR network, and backuped with ISDN links.
All the connections from the central site ( SNA LAN connection with software emulation) are connected to CPA1, trough the DLSw peer between WAN routers and CPA1.
The remotes SNA connection from the remotes sites are connected to the CPA2, trough the DLSw peer between each remote site router and CPA2 with backup peer to the CPA1.
The Problem is :
In the remote site, sometime the fr link and the backup link can have some problem at the same time, the router always try to open a DLSw peer to the CPA2, after the timeout coded in the configuration, the router try to open a DLSw peer to the CPA1 ( the backup peer), after 15 seconds it will try with the primary peer again, after that it will try to the backup peer, and so on.
When the fr link or ISDN link comes up exactly when the router try the backup peer (CPA1), the IBM host don't accept it, and the router stay trying openning the DLSw peer with the CPA1. The IBM Host don't have any information that the remote site are down, and when we look in the IBM host we find that the remote site is connected to the CPA2, so i think the CPA2 give no information about the remote site when it is disconnected to the IBM Host.
Here is the configuration of the routers :
CPA2 :
source-bridge ring-group 2200
dlsw local-peer peer-id 2.2.2.2 keepalive 0 promiscuous
dlsw icanreach mac-exclusive
dlsw icanreach mac-address 4000.0e02.7206 mask ffff.ffff.ffff
dlsw icanreach mac-address 4000.0e13.7206 mask ffff.ffff.ffff
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
ip address 192.168.6.2 255.255.255.248
duplex full
speed 100
interface Channel1/0
ip address 130.114.2.3 255.255.255.0 secondary
ip address 130.114.1.3 255.255.255.0
no ip redirects
no ip route-cache cef
no ip mroute-cache
no keepalive
llc2 dynwind
claw 0122 32 130.114.2.1 DEVL WCPA2 TCPIP TCPIP
claw 0111 22 130.114.1.1 PROD WCPA2 TCPIP TCPIP
csna 0111 20 maxpiu 65535 length-delay 0
csna 0122 30 maxpiu 65535 length-delay 0
max-llc2-sessions 1024
lan TokenRing 2
source-bridge 1100 1 2200
adapter 2 4000.0e02.7206
adapter 3 4000.0e13.7206
CPA1 :
source-bridge ring-group 2000
dlsw local-peer peer-id 1.1.1.1 keepalive 0 promiscuous
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 192.168.6.1 255.255.255.248
duplex full
speed 100
ip address 130.114.2.2 255.255.255.0 secondary
ip address 130.114.1.2 255.255.255.0
no ip redirects
no ip mroute-cache
no keepalive
llc2 dynwind
claw 0122 12 130.114.2.1 DEVL WCPA1 TCPIP TCPIP
claw 0111 02 130.114.1.1 PROD WCPA1 TCPIP TCPIP
csna 0111 00 maxpiu 65535 length-delay 0
csna 0122 10 maxpiu 65535 length-delay 0
lan TokenRing 1
source-bridge 1000 1 2000
adapter 0 4000.0e02.7206
adapter 1 4000.0e13.7206
WAN1 :
dlsw local-peer peer-id 3.3.3.3 keepalive 0
dlsw remote-peer 0 tcp 1.1.1.1 timeout 90
dlsw remote-peer 0 tcp 2.2.2.2 backup-peer 1.1.1.1 timeout 90 linger 5
dlsw cache-ignore-netbios-datagram
dlsw bridge-group 1
controller E1 2/0
pri-group timeslots 1-31
controller E1 2/1
framing NO-CRC4
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 128.114.100.101 255.255.0.0
duplex full
speed 100
standby 1 timers 1 3
standby 1 priority 120
standby 1 mac-address 7206.7206.7206
standby 1 ip 128.114.100.100
bridge-group 1
bridge-group 1 input-lsap-list 200
interface FastEthernet0/1
ip address 192.168.6.3 255.255.255.248
duplex full
speed 100
WAN2 :
dlsw local-peer peer-id 4.4.4.4 keepalive 0
dlsw bridge-group 1
controller E1 2/0
controller E1 2/1
framing NO-CRC4
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip address 128.114.100.102 255.255.0.0
ip route-cache flow
duplex full
speed 100
standby 1 priority 110
bridge-group 1
ip address 192.168.6.4 255.255.255.248
duplex full
speed 100
REMOTE SITE :
dlsw local-peer peer-id 192.1.171.100 keepalive 0
dlsw remote-peer 0 tcp 2.2.2.2 timeout 90
dlsw remote-peer 0 tcp 1.1.1.1 backup-peer 2.2.2.2 timeout 90 linger 5
dlsw bridge-group 1
interface Ethernet0/0
ip address 192.1.171.100 255.255.255.0
half-duplex
bridge-group 1
bridge-group 1 input-address-list 700
interface Serial0/0
no ip address
encapsulation frame-relay
interface Serial0/0.1 point-to-point
ip address 10.1.171.1 255.255.255.252
frame-relay interface-dlci 497
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
ppp authentication chap
interface Dialer1
ip address 172.16.0.171 255.255.0.0
encapsulation ppp
dialer pool 1
dialer string 022430016
dialer string 022262550
dialer-group 1
ppp chap hostname OASIS171
ppp chap password 7 08234F43
router eigrp 2
network 10.0.0.0
network 172.16.0.0
network 192.1.171.0
auto-summary
no eigrp log-neighbor-changes
ip route 0.0.0.0 0.0.0.0 Dialer1 200
access-list 101 deny icmp any any
access-list 101 deny eigrp any any
access-list 101 permit tcp any any eq 2065
access-list 101 permit udp any any eq 2065
access-list 101 permit udp any any eq 2067
access-list 200 permit 0x0000 0x0D0D
access-list 200 deny 0x0000 0xFFFF
access-list 700 permit 0007.1823.e1d9 0000.0000.0000
access-list 700 permit 00e0.18c4.879b 0000.0000.0000
access-list 700 deny 0000.0000.0000 0000.0000.0000
dialer-list 1 protocol ip list 101
bridge 1 protocol ieee
Thank you for your ideas.
rsissons
Level 5
Level 5
You can use the LINGER=0 parameter on the BACKUP peer to force it to tear down the backup peer and reestablish all the circuits with the primary peer as soon as it comes up. That might help you in this situation.
Hallo,
Fist Thank you for your response.
In the remote site router, i can't use LINGER=0, cause the IBM host don't accept the demand of this remote site via the second link with the CPA1 router, it still see the IDNUM IDBLOCK active via the CPA2 router.
I think that i must change the Keepalive parameter in the CPA1 and CPA2 router to 10s or more, cause i coded keepalive0 in the remotes sites to stop the DLSw keepalive via ISDN if the primary link goes down, but the CPA2 router have no isdn connection.
My question stay : if the CPA2 router have no information from the remote site (after the keepalive expires), the IBM Host will clear the IDNUM IDBLOCK for this remote site or NOT??
I'm not a DLSw expert, for that raison i have some questions without response. Thank you for your response another time.
