Example to create vPC on 5K with third party Layer 2 switch?
Julio E. Moisa
I would like to know how should be a good vpc configuration on 5K for a layer 2 third party switch. Any example will be appreciated? I have 2 Nexus 5K and 2 third party L2 switches
Thank you
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Mark Malone
Hi Julio
 on the 5k side you just setup a vpc port-channel config identical on each 5k use LACP active as below , and on the layer 2 switch just use a standard port-channel and connect a link to each 5k , depending on what the 3rd party switch is but most should support LACP these days
you can connect up standard cisco switches like that too that don't understand vpc feature , stacks as well can be split across 5ks as well vpc etherchannel to standard etherchannel
interface port-channel10
  description **TO_L2_SWITCH**
  switchport mode trunk
  speed 10000
  vpc 10
interface Ethernet1/9
  description ***TO_L2_SWITCH***
  channel-group 10 mode active
interface Ethernet2/9
Mark Malone
Hi Julio
  speed 10000
  vpc 10
Thank you so much Mark!
