FEX Chassis Numbering
SATORU SAEGUSA
Frequent Visitor
Frequent Visitor
Hi, Can I use same chassis ID number to two Nexus with vPC single-homed topology? !!! N5k-1 and N5k-2 configuration feature fex feature lacp feature vpc slot 101 provision model N2K-C2232P exit ! fex 101 pinning max-links 1 type N2232P exit ! interface E1/1 - 2 no cdp enable channel-group 101 no shutdown exit ! interface po101 switchport mode fex-fabric fex associate 101 exit Thank you for your cooperation in advance.
2 Accepted Solutions
Reza Sharifi
Should not be an issue.  The FEX IDs are locally significant.
Arigato,
As Reza said you can go ahead with the same.
Please find below document URL:
Inayath
Reza Sharifi
Hello, Reza-san.
Thank you for your answer.
Please let me know the document URL on Cisco.com website if you know any.
Arigato!
Arigato,
Inayath
Hi, Inayath-san.
Thank you for your clear answer!
Kind regards,
Satoru
