Firmware crash in Cisco Fbric Interconnect. How to fix it..?
Ninad Thakare
I have a Cisco 6248UP Fabric Interconnect which I am suppose to keep a Primary in Cluster. So, I did the configuration according to it, Secondary is not yet attached. I am able to browse the this FI but not able to take access/login it.
When I tried to search the cause from CLI, I found the Firmware is crashed.
Current Firmware :
bootflash:/installables/switch/ucs-6100-k9-system.5.0.3.N2.2.11e.bin
The error I found
I want to upgrade the firmware to 2.21d
How can I do it through CLI/Console.
Ninad Thakare
Keny Perez
Level 8
Level 8
the upgrade through CLI is too complicated compared with the same process done through the GUI.  If you have access through CLI, can you tell me what is the version of firmware running on the FI?
Also, what is the specific error you receive when you try to connect through the GUI? Could provide an screenshot of it?
Rate ALL helpful answers
-Kenny
