Help in Security Solution for N1Kv Design
Daniel Stefani
My customer is migrating its Datacenter Environment, similar to the attached picture.
Today, they have a 6500 Core Switch with FWSM providing Security for Inter Vlan access.
Using N1Kv + N7K with the same Inter Vlan connectivity, what is the best option to provide Security Policies and enjoy the 20GB Uplink ?
One ASA 1000v Instance for each VLAN is a good option ? I will not have performance problems ?
Thank you in advance for help ..
Daniel Stefani
ASA 1000V is a tenant edge firewall. It is recommended to isolate tenants from outer world and from each other. An ASA 1000V always has only two interfaces so multiple instances result in a firewall management question.
Simple Inter-VLAN (and even intra-VLAN) filters can be implemented by VSG if protocol inspection (fixup) is not a requirement.
Daniel Stefani
Any Help? This is the correct place to post this doubt?
Best Regards,
Daniel Stefani
