How configure jumbo frames on nexus 5000 at interface level
mhosamani
I am able to configure jumbo frames on nexus 5000 at switch level, however i want to do the same at interface level, is there any way that can be done ? is it supported ?. i dont want all my ports to be configured with jumbo frames in one shot.
Manju
Jerry Ye
If it is L2 only, system level config will take care of it.
The only time you need to configure it on the interface level is when you have L3 interfaces.
jerry
Jerry Ye
jerry
Thanks Jerry, i got your point. As i was seeing this possible in brocade 8000 switch, wanted to know if possible in nexus 5000 as well.
Manju
Jerry,
Does this mean its not possible to set at interface level in nexus ?
Manju
For L2, you don't need to set it at interface level (it will not do anything), set it at system qos will take care the job.
jerry
