Server Networking
Cisco UCS X-Series Energy Efficiency Offer
Hello,I have two of the NVIDIA DGX V100s. They're the same specs as the standard PCIe & SXM2 V100s, except they have DisplayPort output (which I don't need and won't be using). I like my C240 M4s, so I picked up a used C240 M5 because it supports the...
Hello,I found documentation discrepancy about the ports speed capability of the Nexus 9348GC-FXP.The datasheet from Cisco is : https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-742284.html This datash...
Hi, I have an Iot server configured on one of my packet tracer files, and for some reason when I try to create conditions at my Iot Registration server I click ok but the condition I made doesn't show up, as if it is invisible. Can anyone tell me how...
Hello,I am trying to implement a VXLAN configuration to extend a VLAN from our main site to different sites for a guest network. My environment uses VRF routing tables to separate our production network form our guest network while utilizing EIGRP fo...
Hello,I have multiple C92160YC-X  but it looks like this one does not support QinQ / Dot1Q tunnel ports is this correct? i cannot find option to enable this feature, or is this maybe a firmware issue?We have also C3064PQ which do support this functio...
sander64 by Level 1
  • 776 Views
  • 2 replies
