Inter-vlan routing and vPC topology
jay3
Hi Guys,
Is it possible to use inter-vlan routing in the attached topology.I want the two servers to be able to communicate through the default gateways configured on the Nexus switch/es.After I achieve basic
inter-vlan routing,I would prefer to have HSRP at a later stage for more redundancy.
Thank you in advance.
Yes, the vpc peer-link would be carrier of the hsrp hello.
No, you don't need to track fex interfaces, that will be automatic by the nexus.
mlund
Level 7
Level 7
Yes it's possible. But you have to configure hsrp from the beginning, otherwise traffic that ends up in the "wrong" switch will not be routed.
With wrong I mean, traffic from servers can use both uplinks because of the portchannel. And if taffic comes to the switch that is not configured with the vlan routing.
/Mikael
Thank you for your response Mikael.
If i were to use HSRP,which link would be used for the HSRP keep-alives? Do the HSRP keep-alives use the vPC peer-link? If so,would I have to use object-tracking as well so I can monitor the failure of a link that connects to a FEX?
Rgds,
Jay
