Interface down when migrating c3750x-48 interface to Nexus 93108TC-EX
samuel peter
Hello Community,
I have encountered interface down when migrating c3750x-48 interface to Nexus 93108TC-EX.
The end host is a legacy network and it uses 100M interface.
Nexus 93108TC-EX has GLC-TE interface to accommodate migration coming from c3750x-48.
Below are the configuration, interface properties, and status:
c3750x-48: Current Connection
3750# show int status | i connected
Gi1/0/1 XXXX connected 200 full 100 10/100/1000BaseTX
interface GigabitEthernet1/0/1
description XXXX
switchport access vlan 200
switchport mode access
speed 100
duplex full
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is aaaa.bbbb.cccc (bia aaaa.bbbb.cccc)
Description: XXXX
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 11000 bits/sec, 18 packets/sec
5 minute output rate 20000 bits/sec, 20 packets/sec
2635341311 packets input, 291807457942 bytes, 0 no buffer
Received 68731 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
2713034794 packets output, 567479861491 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
93108TC-EX: Destination port
interface Ethernet1/1
description XXXX
no cdp enable
switchport
speed 100
duplex full
no shutdown
Port Name Status Vlan Duplex Speed Type
Eth1/1 XXXX notconnec 200 full 100 10g
TSHOOT:
Apply interface as spanning-tree port type edge but to no avail.
I tried to undo hardcode to use auto neg but still physically down.
93108TC-EX(config-if)# no speed 100
93108TC-EX(config-if)# no duplex full
93108TC-EX# sh int status
Eth1/1 XXXX notconnec 200 auto auto 10g
Is this something related to negotiation, duplex, speed still?
I just notice that the MDIX is off on nexus interface by default, I haven't tried to enable. Can this be solve?
balaji.bandi
try
no negotiate auto
if not work post show version may be looks like bug.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu79156/?rfs=iqvred
BB
