Internet speed problem
pajorgensen
Community Member
I am using a 3825 as an edge router. It has only the two integrated gig ports hard set to 100/full. On my side is a 6509 (hard set to 100/full)and on the ISP side is a Riverstone 10/100 switch (set to 100/full). I can only drive the throughput to about 2000pps at about 10Mbs (combined both in/out). Once in a while I see spikes over 10Mbs.
I noticed that my 6509 doesn't support flow control on the 100BaseT ports but the 3825 says flow control is set to XON. I can't find any command to change this. Could this be a problem?
10 Replies 10
sandipani
Community Member
Hi:
Cisco 6509 switch if the switch running with CatOS then you can do the flow control by changing the port speed.
Sandipani
??? I am running hybrid os but the "set port speed" command has no options for flow control that I can see.
When I do a "set port flowcontrol" command I get "flowcontrol mode 'on' not supported on module"
How are you testing pps? What size packets are you using?
Testing throughput or bandwidth using any kind of TCP/IP transfer will not be accuarate due to varying packet sizes, acknowledgements, and other TCP overhead.
PPS is just by the counters on the interface. I am not tracking sizes. Bandwidth utilization is monitored by MRTG and flattens out at 10Mbs with spikes up to about 18Mbs.
CSCO10408957
Level 2
Level 2
Please Check 3825 interface config:
interface GigabitEthernet0/0
duplex full
speed 100
media-type rj45
negotiation auto
description $ETH-LAN$$FW_INSIDE$
ip address xxx.xxx.xxx 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
load-interval 30
duplex full
speed 100
media-type rj45
no cdp enable
no mop enabled
hold-queue 2500 in
hold-queue 200 out
The config. looks fine. Did you confirm the ISP did not limit the throughput and find any packet when it reach 10M or 18Mbps ? Please provide the "sh int".
Sorry. I mean do yuo find any packet drop when it reach 10Mbps or 18Mbps.
I am working with the ISP right now. I am just trying to rule out anything on my side. I noticed the flow control thing (see my first post) and didn't know if that would affect throughput.
Thanks for all the responses!
GigabitEthernet0/0 is up, line protocol is up
Hardware is BCM1125 Internal MAC, address is 0012.7f29.04c0 (bia 0012.7f29.04
0)
Description: $ETH-LAN$$FW_INSIDE$
Internet address is xxx.xxx.xxx.xxx/27
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 11/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is autonegotiation, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2w4d
Input queue: 0/2500/0/86 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/200 (size/max)
30 second input rate 1078000 bits/sec, 502 packets/sec
30 second output rate 4419000 bits/sec, 612 packets/sec
553006601 packets input, 3478560860 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 940490 multicast, 0 pause input
690657734 packets output, 1645866688 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
I don't find any problem of the interface. There is only one issue that the config. show it is manual config. of speed/duplex but it is auto from the sh int. Can you clarify it is manual setup ?
There is no packet drop at the interface, will the limitation is carried on the end device, e.g. your LAN side or the remote side behind the ISP ?
I suggest to disconnect the GE from the ISP and try to connect the GE to a PC then make a throughput test locally. If there is no problem, it is the ISP issue or the remote end host issue.
Hope this helps.
