is SPAN port not allowed in Nexus FEX Port ?
lin chang
    Customer want me to defined a SPAN port on N2K, it is a fex port. when I configure I got the following statement from the switch.
Is there any way to solve the problem?
n5k-N2K(config-monitor)# destination ?
  interface  Configure interfaces
n5k-N2K(config-monitor)# destination interface eth102/1/18
ERROR: Eth102/1/18: Configuration not allowed on fex interface
N5K VERSION
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2009, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.2.0
  loader:    version N/A
  kickstart: version 4.0(1a)N2(1)
  system:    version 4.0(1a)N2(1)
  BIOS compile time:       06/19/08
  kickstart image file is: bootflash:/n5000-uk9-kickstart.4.0.1a.N2.1.bin
  kickstart compile time:  2/25/2009 0:00:00 [02/25/2009 08:29:12]
  system image file is:    bootflash:/n5000-uk9.4.0.1a.N2.1.bin
  system compile time:     2/25/2009 0:00:00 [02/25/2009 08:56:57]
Reza Sharifi
A FEX port cannot be configured as a SPAN destination. Only a switch port can be configured and used as a SPAN destination.
See link below for more info:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_1_3_N2_1/Nexus5000_Release_Notes_5_1_3_N2.html
lin chang
Thank you very much
