Nexus 1000v. Only first VM is able to ping outside vlan interface.
Faisal syed
Hello everyone,
I am trying to setup Nexus 1000V VSM and VEM.  My ESXi host has four network ports. For management I am using only one of the ports on the quad nic card as a trunk.  It is trunked to Cisco 3750 switch.  Another one of the quad nic cards is connected to the VDS.  Both ports are in port channel 1.  I moved three VMs from vSwitch to vds . But somehow only one vm which I powered on first is able to ping outside vlan interface, others won't. They only work after I issued command in port-channel 1 shut and no shut. When I reboot the host, it is back to where the first vm can ping outside vlan interface.
Here is the configuration for the Nexus port profiles and the 3750 switch.
port-profile Unused_Or_Quarantine_Uplink
type: Ethernet
description: Port-group created for Nexus1000V internal usage. Do not use.
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  shutdown
evaluated config attributes:
assigned interfaces:
port-group: Unused_Or_Quarantine_Uplink
system vlans: none
capability l3control: no
capability iscsi-multipath: no
capability vxlan: no
capability l3-vservice: no
port-profile role: none
port-binding: static
port-profile Unused_Or_Quarantine_Veth
type: Vethernet
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  shutdown
port-group: Unused_Or_Quarantine_Veth
system vlans: none
port-profile VMK-Control
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode access
  switchport access vlan 9
  no shutdown
  no shutdown
  Vethernet2
port-group: VMK-Control
system vlans: 9
capability l3control: yes
port-profile VM_VLAN2
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 2
  no shutdown
  no shutdown
  Vethernet1
port-group: VM_VLAN2
system vlans: 2
capability iscsi-multipath: yes
port-profile VM_VLAN3
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 3
  no shutdown
  no shutdown
  Vethernet3
  Vethernet4
port-group: VM_VLAN3
system vlans: 3
port-profile VM_VLAN6
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 6
  no shutdown
  no shutdown
  Vethernet7
port-group: VM_VLAN6
system vlans: 6
port-profile VM_VLAN8
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 8
  no shutdown
  no shutdown
port-group: VM_VLAN8
system vlans: none
port-profile VM_VLAN9
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  no shutdown
  no shutdown
  Vethernet5
  Vethernet6
port-group: VM_VLAN9
system vlans: 9
port-profile uplink_Connection
type: Ethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode trunk
  switchport trunk allowed vlan 1-10
  channel-group auto mode on mac-pinning
  no shutdown
  no shutdown
  port-channel1
  Ethernet3/5
  Ethernet3/10
port-group: uplink_Connection
system vlans: 1-3,6,8-10
********************************3750 switch configuration************************************
Switch>en
Switch#show run
Building configuration...
Current configuration : 3862 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision ws-c3750-24ts
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
spanning-tree vlan 9 priority 4096
vlan internal allocation policy ascending
interface Port-channel1
switchport trunk allowed vlan 2,3,6,9
interface Port-channel2
interface FastEthernet1/0/1
interface FastEthernet1/0/2
spanning-tree portfast
spanning-tree port-priority 0
interface FastEthernet1/0/3
channel-group 2 mode active
interface FastEthernet1/0/4
interface FastEthernet1/0/22
channel-group 1 mode active
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
interface Vlan2
ip address 20.12.162.1 255.255.255.0
interface Vlan3
ip address 20.12.161.13 255.255.255.0
interface Vlan4
ip address 20.12.165.1 255.255.255.0
interface Vlan6
ip address 20.12.166.1 255.255.255.0
interface Vlan9
ip address 20.12.167.1 255.255.255.0
interface Vlan10
ip address 20.12.168.1 255.255.255.0
router eigrp 100
network 20.12.161.0 0.0.0.255
network 20.12.162.0 0.0.0.255
network 20.12.165.0 0.0.0.255
network 20.12.166.0 0.0.0.255
network 20.12.167.0 0.0.0.255
network 20.12.168.0 0.0.0.255
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 20.12.165.2
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
**************************Trunk-status*******************************************
switch# show int trunk
Port       Native  Status        Port
           Vlan                  Channel
Eth3/5     1       trnk-bndl     Po1
Eth3/10    1       trnk-bndl     Po1
Po1        1       trunking      --
Port       Vlans Allowed on Trunk
Eth3/5     2-3,6,8-9
Eth3/10    2-3,6,8-9
Po1        2-3,6,8-9
Port       Vlans Err-disabled on Trunk
Po1        none
************************************MAC pinning**************************************************************
VEM modules are loaded
Switch Name      Num Ports   Used Ports  Configured Ports  MTU     Uplinks
vSwitch0         128         4           128               1500    vmnic5
vSwitch1         128         4           128               1500    vmnic8
vSwitch2         128         1           128               1500
DVS Name         Num Ports   Used Ports  Configured Ports  MTU     Uplinks
switch           1024        20          1024              1500    vmnic9,vmnic4
VEM Agent (vemdpa) is running
~ # vemcmd show iscsi pinning
Vmknic   LTL      Pinned_Uplink    LTL
vmk2     49       vmnic4           21
vmk2 is pinned to the right vmnic. It supposed to be pinned with vmnic9
Thank you all for your help in advance.
Also, I need some guidance on binding vmnic to vmkernal in VEM.
Faisal
sprasath
Hi Faisal,
- Please paste the outputs of 'vemcmd show port' and 'vemcmd show port vlans'
- Mention the name of the VM that is working and the ones that are not working
- vmk/vmnic/vmhba binding is done at the ESX level. The VEM is not involved in this.
Shankar
Thanks Shankar for your response. I figured it out. It was port-channel configuration issue. I had connected the uplink directly into vlan 2. I should have  added that interface into port-channel.
Thanks again.
