Load Balancing question
ronaldcochran
Community Member
My company is in the process of building a small scale network architecture strictly for testing purposes. We have a DMZ area that contains 2 load balancers and 1 web server. The web server is a SunFire 280 and has two gig e nics. They want to cable one nic to one load balancer and one nic to the other. Since this is only one box we have to put the nics on separate subnets. The question is, can I configure the load balancers in a failover situation of an active active situation with one load balancer on one vlan and another load balancer on a separate vlan.
dixho
Level 11
Level 11
I think that we do not have the expertize to answer your question in this area. Please try "Content Networking" under "Emerging Technologies."
hi
wht type of load balancers r u using in u r N/W ??
regds
prem
ashmanpan
Community Member
I did not able to understand why you want to give ip to two NICs from different subnets.
There is NO any requirement, like that. If you have your own requirement can you explain me that?
Ashman
